Is this on the ballast's output or right at the coil itself?I just checked v at the ballast, nearly 11 in run, 12 in start. Checking at the coil, it's high 4s in run, 7s in start.
Also, on the clutch front, I know you can't tell from this, but it seems like a lot of free play to me. It's 100% moving the fork so the oval hole has nothing to do with this. You can see the rod to the fork moving.
Both. Higher numbers are at the ballast, lower numbers are at the coil.Is this on the ballast's output or right at the coil itself?
Yeah I know but I'm tired of putting the dumb thing up on stands.You really have to measure the travel at the fork itself
It was about 11v in both start and run positions.Try unplugging the ECU and see what your readings are at the coil.
The ballast wiring seems correct. The ECU taps into the blue wire. The ECU plug/wiring harness is new. Just the voltages are wrong. There are no dirty terminals involved. It doesn't make sense. The voltage is correct in start and run until I plug in the ECU.Something's definitely wonky there. If you've got 11-12V at the ballast output but only 7 at the coil's (+) terminal, then that wire is suspect, but I wonder about the wiring itself since it's obviously not original--only a genuine 340 car could've had it, which is fairly uncommon, and it would've had a 4-pin. At one side of the ballast--the one feeding directly to coil (+), you should have two wires, both 14ga brown. One goes to the coil, the other to the start circuit on the ignition switch to bypass the ballast and provide full voltage when starting. On the ballast's other end, you should have one 16ga dark blue wire. It's fed by the run circuit of the ignition switch. There should also be an 18ga light blue wire with a yellow tracer that runs to the ECU.
In "START" both brown wires at the ballast and the one at the coil (+) should have nearly battery voltage. The other end should read about the same.
In "RUN" the brown wire, both at the coil and the ballast, should read ~8V, while the blue wire should have battery voltage or damned near it.
I think the rule of thumb is that canister coils should be mounted upright regardless of brand. Lying on their sides facilitates oil leakage in the case of overheating or a seal failure. Truth is, if you boil it with too much voltage or dwell, the oil's coming out regardless. The 8203 in my '81 Imperial was upright on the firewall. It didn't help; oil was pouring down the sides onto the firewall and transmission.FWIW I just read that the common MSD coils should be mounted vertically. So much for mounting one with a factory bracket. I'm pretty sure the one I've got has been mounted horizontally all along though.
I've got one of these too
I did, but not known-working. The one that I started with was working when I drove the car into the garage. It had a voltage drop the last time I was fighting battles on it too. I had 3 4-pin and 2 5-pin units laying around. I chose the best looking one of the 4-pins.I'd try performing the same tests with a different, known-working ECU.
Inquiring minds want to know why the hell the factory mounted them horizontally?I think the rule of thumb is that canister coils should be mounted upright regardless of brand
It really doesn't. If you look at the factory setup, it's essentially just a jumper wire. I always wired for the 5-pin myself, because the 5-pin arrangement will run just fine on a 4-pin module. The opposite is not true.Part of me questions if going to a 5-pin and a 4-pin ballast would help, since that kinda sorta separates the coil circuit from the ECU circuit.
I don't understand this. The battery has more than enough reserve power to not sag ~4V at the ballast (either side). Most batteries sag maybe 2V with the starter engaged. Unfortunately at the moment I don't have a vehicle against which to test this, because the only runner is the '68, and it's points. Agnes has a Pertronix.ECU draws alot of amps in the run position engine off. 4 amps usually running 2.5 ampsish. Prob what you are seeing.
...they're two completely-different measurements of different electrical properties. They don't convert to one another.Need to convert amps to volts to see if that pans out, which I can't do because...
I'd think you're looking at either a ground issue somewhere at the rear of the car, or something amiss with the turn-signal switch.OK, I accept that it's the same as it was when the 400 was running so it will run again, and continued checking the electrical. I walked around behind the car to check the backup lights (dash light works) and about the time I turned to look at the car I realized I didn't have the key on. But hey wait a minute, why are both brake lights on? It took a second for me to realize I forgot to re-adjust the switch at the pedal so I had to take the seat out one more time. That answers the question of why the ammeter shows a discharge.
Then when I used my phone to video the lights while I pressed the brake pedal, only the passenger side worked. Both sides worked before I fixed the switch so I just put that on my list of things that don't matter right now and moved on.
I would certainly think so. There's not much load on the engine in neutral so it shouldn't use nearly the fuel it would while driving.Is 5 gallons enough to run the engine for half an hour? It should be, right?
That's the first thing I thought, too bad I don't have another car to compare.Unfortunately at the moment I don't have a vehicle against which to test this,
I'll get it going again, it's just weird that both lights worked until I adjusted the brake light switch.I'd think you're looking at either a ground issue somewhere at the rear of the car, or something amiss with the turn-signal switch.
In somewhat defense of such a foolish statement, it's sort-of a plausible scenario. However, it's only possible on a 4-pin ballast if and only if the alignment pins have been broken off the connectors. If the pins are in place it can only connect correctly regardless of which end the connectors are installed.FWIW I had an apparently respected member over there ask me if I had the ballast resistor hooked up backward. I know that doesn't matter so I took the diplomatic route and said I didn't know you could do that, and explained the orientation of the ballast and the wire connections. Good grief.
"At least" being the operative phrase in that sentence.I can think of at least one off the top of my head who'll rant and actually insult people while being 100% wrong.
