An even-better shot I found in my thread. Note: That's not the correct shifter mount. That's for a 1966-'68 Inland reverse-trigger unit.
The 1968-'71 A-body Hurst shifter is the most-common one since it's the same as 1968-'70 B/C-body and the 1976-newer trucks with the A833OD. The truck shifter had a grease fitting in the side of the case. Yes, those parts also fit 1966-'67 B/C- and 1967 A-body, but none were built that way. That being said, the mechanism to have is the 1972-'75 A-body one, which uses a bolt-in handle rather than the slip-in "bayonet" style used in the other applications that interchange. The easiest way to identify the shifter is by the levers, with the reverse arm having a noticeable rear curvature. Here's my truck shifter on an A-/F-/M-body overdrive for my '68 Valiant:
I have since bought the parts from Brewer's to convert the shifter to a bolt-in handle. It's absolutely worth the effort and expense.
The only major difference on the overdrive setup is the 3-4 rod, but even that uses the same transmission lever. The factory transmission levers are stamped R, L, and D for reverse, 1-2 ("Low"), and 3-4 ("Direct") respectively. The stamped marks are exclusive to A/F/M series; no other model or make were stamped as such.
The aftermarket Hurst
close-ratio shifter has a bolt-on handle, straight reverse arm, spacers between the shifter mount and trans, and uses different linkage rods and levers. I don't have the stamping numbers for the parts here, but if you've got a straight reverse arm. I believe that one may also use the 1964-'65 shifter mount, but I don't have the resources here to double-check.
overdrive setup was a needlessly-fussy arrangement using the same straight-reverse-arm mechanism, a mishmash of linkage parts from other applications, a unique 3-4 lever and reverse rod. I've been trying to assemble one for several years now. The two overdrive-only parts almost never appear on eBay--only one 3-4 lever (which I bought) and I've never seen the reverse rod for sale anywhere.
The irony is that the aftermarket close-ratio setup fits and works on the overdrive if you simply flip the 3-4 arm:
I have more f__kin' Hurst linkage parts (especially A-body) than I'd care to admit, so if you find yourself in need let me know. I'll dig through
Ye Olde Linkaje Bocks and see what appears. Also, double-check the stamping number on the shifter mount. There are a couple that look identical but don't interchange, and the 1964-'65 mount doesn't play nice with the later shifter mechanism and handle.
