thrashingcows
You still have to gap it, Bob.![]()
And no a tape measure is not what you use either....
I had to do something similar on a /6 to 340 conversion I did. IRRC it was one or two pieces of 16ga, whatever that adds up to. That was with Schumacher mounts so they might even be exactly the same thing with more finishing on the Schumachers.I used the Trans-Dapt Slant-to-LA conversion mounts in my Valiant. They had a similar price difference, and I couldn't figure out why either. They worked splendidly. The only mod we did was use a chunk of metal plate around 3/32" thick as a spacer on the driver's-side mount for header clearance.
I was surprised to see the Schumacher mounts even listed as available. From my understanding, most of their stuff has been intergalactically backordered for a few years now. Either way, though, the price difference between those and the Trans-Dapt means I'd prefer to screw with the latter rather than part with the extra cash. The Trans-Dapt stuff predates Schumacher by a decade or more.
That is why I can't even consider using the elephant ears on the 440 - those (mine anyway) have the engine up 3/4-1" already because the oil pump is well above the k-frame mount.Rmember, the 440's more than an inch wider than a 400 due to it's .74" taller deck height, so clearance will be at even more of a premium than it already is
I typically run a solid mount on the driver side and a rubber one on the passenger side. I promise you after driving the car with those elephant ears it will still "ride like a cadillac" even if I used both solid mounts. But the mounts used in the Transdapt kit are "TD 4221; OE pads for 69-71 Dodge D/W-Series truck (225/3.7L) (ie: 2266, 602266)" so it's kind of doubtful I'm going to be able to find a solid version of that.The spool-type mounts are "fail safe", meaning they can't rip completely loose.
IIRC the spool mount swap kit (Schumacher only) is about 2x the price of the biscuit mount kit, which is about 2x the price of the Transdapt kit.An A-body spool K-member shouldn't be too tough to find, but the B/RB mounts might be a bit pricey.
Yeah, like I would trust my welding enough to do that. I'd have to find a mobile welder to come out so there goes another $100-200 up in smoke. Even if I trusted my welding, all I've got is a 110v Lincoln 140 and it seems like I'd need something more capable. Maybe not. But I'd definitely need more skill.Another option would be to carefully remove the spool tabs from any K-member so equipped and weld them to your existing one after you've removed the biscuit perches.
assuming your hose nipples are on the right ends of the radiator tanks
Hey, my buddy's girlfriend is getting a grungy, used 4937S AVS carburetor. It's the correct one for her M3 Duster 340, which has the factory ECS. Tough carb to find.I will give them to Gina as a Christmas gift.
Seriously I may give them to her to give to me if she gets hung up on it.
I wouldn't mess with any ball joints. In fact, I wouldn't even touch the upper control arms.I studied this some.
Before re-assembling the car I should take the UCAs off the spindle at the UBJ, because it is a hassle to get them bolted back to the body with the weight of the spindle, brakes, etc hanging from them.
The K-member uses specific shouldered bolts that correctly locate it. Once you've got two started, simply snugging them will perfectly align the K-member to the other two bolt holes. It's a surprisingly precise arrangement.69.5CUDA said:as far as re-alignment of the k member, your over thinking it...with the wheel dolleys you just wiggle it around till it aligns with 1 hole put a bolt in and then wiggle it for all the rest, DO NOT tighten any of them beyond a half way in till all 4 are in
