b-body-bob
I still think they are all wet. I meant to go back to the 452s and see if they're the same but forgot.
I got distracted by the header stuff and forgot to reply to this post.Rock auto has one for 51.89 + 40 core.
This is the Powermaster next to a Mopar Denso
Absolutely. It makes no sense except maybe from the manufacturer's POV (Profit Oriented Vending)I got distracted by the header stuff and forgot to reply to this post.
One big problem I see with the Powermaster is that it does not have the bellhousing pilot to ensure correct alignment between the starter drive and flywheel. Not only does that allow greater deflection of the starter's shaft, it's lacking the bushing in the pilot that eases the load on the rear bearing inside the starter housing. Since more deflection = more load on the rear bearing, it's a downward spiral. I would not expect particularly great life from the starter, with shaft bind being a failure mode.
I think it's hooey.What do you think about burning valves with uncapped headers?
I think it's hooey.
It'll be fine running open headers. I've seen engines run with open exhaust ports that didn't burn valves.
Yeah I know what you mean. That was part of why I wrapped them all the way around the shroud instead of trying to get fancy and wrap them so the only go in and out of the holes intended. The way they are there's fewer places where the tie touches the bracket. I was also wishing I would've used more than one per hole, just in case.I’d worry about those zip ties getting cut by the combination of vibration and the edge of metal.
Maybe just change them as part of maintenance?
I don't have to see it to imagine it.Ever see a fan go all jujitsu on a shroud and shred the radiator? It happens.
