Diplomat_Wagon
Hiding In The Bushes While
Looks great! Now its time to organize
Benches and shelving are next as the pad is too cold to coat right now.
How does the concrete need to cure before coating? Yes, I can see your point building/adding benches & shelving before organizing
what brand are you useing on the floor?.....i just want to make sure its not the same GARBAGE that was used up on the 40......its tough and fairly resistant but chip it and it comes up like semi soft latex...and gas eats it right off...like you cant wipe the floor fast enuf before its allready destroyed
The stuff I want to get is a 2 part epoxy, its like $1200 for enough to do about 650 sqft, but its oil and chemical resistant. We used it in the parts room for a private airline. Its holding up great so far and its been a couple years.
ugh that sounds like the same crap we used..5g can ..a blue can at that..i dont have the name infront of me...but the stuff is GARBAGE..even the priice sounds the same
id go with epoxy..you can do it yourself its just a PITA....but id rather have a floor be a PITA to go on and last a life time
I don't think you would want to do an epoxy in the winter unless you have a respirator. :dgt:
Most epoxies give off toxic fumes. [smilie=f:[/QUOTE]
This is an acrylic coating but fumy none the less.
I have a very nice charcoal respirator and I intend to use it, I also have that vent fan in the wall that I will be running.
I will have the heat up in there while I wash the floor and leave it up until it's dry and ready to coat.
Vent fan?
Electric motors and fumes = potential boom boom.
Is it a sealed motor?
Or is it belt driven and the motor is out the way of the flow?
It's a long shot, but......
