thrashingcows
Now the fun part. Install the brackets and try and get all the measurement s to line up...
I spent a couple hours running back and for to the computer to check all the measurements. I eventuallt got it all blocked up and in position.
I then noticed that the Driver side rear most upper hole in the bracket lined up almost perfectly with the center hole left by a rivet I pounded out.
The passenger side was off just a little....
I decided to install bolts and see where my measurements would fall.
So with the main center cross member bolted in using those two holes, All my measurements are within a 1/16th to 1/8th...and some are dead on. Think I can live with those measurements. So tomorrow I will double check the measurements one last time, then start drilling.
