Stretch
Finally back on ol' Stinky.
I started the spring relocation process. I started by setting the car on jack stands in front of the rear spring front mounts and removing the rear of the rotisserie from the back of the car. I left the front of the car attached to the rotisserie. The back needed to be removed because it was bolted to the factory shackle mount location.
Next I test fit the hangers, marked the frame rails where the bushing tube goes through the frame rails and cut the holes for that tube with the plasma cutter.
I then welded them in and called it a night.
