Yesterday's progress...
Whilst walking around the compound
, I saw the RH fender I'd picked up for the LeBaron a few years back still sitting where I'd placed it when it came home. Being it's been sitting outside for a few years, I thought it high time I did something about protecting it from further rust damage. I removed it from its resting place and proceeded to attack it with chemicals and tools.
First up was the chemical stripper to remove the OEM paint, which (surprise) hid a medium-sized spot of plastic filler. It's not really uncommon on older cars, nor is it the first time I've seen it. There's a pretty-decent dent it was covering; I did nothing about it now since I don't want to start bodywork on the car until it's bolted together; if I fixed it now, it could well come apart once the fender's bolted in place and it's under tension.
After the stripping agent had done its thing, I attacked it with my 4½" angle grinder and a knotted cup brush, to remove rust and prep the rest of the surface for the Chassis Saver (it won't cling to smooth metal). Once it's scuffed (no easy feat, by the way) I can do bodywork over the Chassis Saver, so I decided to coat the entire fender rather than just the problem areas of the lower edges and wheel arch.
I loaded up my crappy touch-up gun with the Chassis Saver and shot the panel. I waited the prescribed flash time and shot it again, then cleaned my gun really,
really well.
The paint laid out nice (it always does if you don't run or sag it), and I was very happy with the results. Unfortunately, I ran out of paint stripper and wasn't able to take care of the inside or front; I've got more stripper but no energy to tackle it tonight since my 3-day weekend was much like a marathon--car, Tina's house, graduation party, etc. As nice as it looked last night, I went out there this morning only to find a bird had shat upon it. :doh: We'll see shortly how well that paint holds up to avian droppings.
The heavily-pitted areas will get a skim coat of plastic filler; I'd like to attempt actual metalwork on the dent to try and straighten it as much as possible before the I break out the filler. Again, I won't attempt that until it's bolted to the car.
Anyhow, enjoy some more pictures:
