Oh I'm sure it will.Hopefully the blasting won't reveal anything you don't already know about.
Yes. I know. I was referring to what I found after sanding through the paint. I have just barely started with the sandblasting.Not clean enough, my friend...
Seal the housing leaks and build a cyclone for your shop vac. I made one out of a steel 5-gallon pail and some exhaust tubing... absolutely my favorite home-made tool ever. I can easily see what I'm doing and virtually nothing ends up in the shop vac.You must have some industrial strength PPE to be sandblasting in the open like that.
If I run my HF sandblast cabinet for more than a few minutes you can see it hanging in the air. (I really need to try to fix that)
