b-body-bob
Hooray, a new water leak started in the crawlspace this morning. Went under and scoped it out and at least it's not on the side where I have to crawl to the other end and then back around to the leak..
There are other blue spots on the pipe that's leaking that will eventually turn into leaks. I'm going to replace about a 4' piece with SharkBites this time because that's the length of the partial stick I have on hand. I will use a standard shark bite on one end, and a slip-joint fitting on the other.
I'm gonna have to replace it all in PEX. Actually I should've done it already, but it's easy to put crawling in there on the back burner. Other than that I've got two hold-ups:
1: It's a crawlspace so I can't use a roll of pex to minimize the couplers. I would never get it to roll out and I think it would turn into a mess trying to strap it as it unrolls. The truck bed is only 7' long and I'm unsure if I can get 20' sticks back home. The house is 60' long x2 hot and cold with two baths and the kitchen connecting into the main lines that run end to end.
2. The fixtures all have the supply riser coming up an interior wall so there's no easy way to replace the endpoint of the runs. I've been told the vertical lines rarely leak, it's always the horizontal ones and it's caused by sediment build up or where somebody strapped copper with steel. I could sharkbite them from there into PEX, but that's expensive and unreliable. I could solder PEX couplers to the copper risers, but I've had no good luck with that in the past. At least the pipes are vertical so when the water's drained out, it's all drained out. I can't say for sure there's room to do that because they might be too close to a joist.
For now, I just want to get the water back on. Almost as much as I don't want to crawl back in there again.
