Project progress delayed for the time being.
When I was in my 20's I would be workin' on it right where she sits. :dgt:
No garage available.:doh:
That ain't no reason to quit!
Your young!
-Get out there with a shovel, dig it out and get back to work....
On a side note I scored some sweet 408 stroker parts and have a line on a 518 OD for this car and am also in the process of looking for a 5.9 Magnum core.
I also managed to dig up a set of 3.91 gears and a 9.25 SG.
That is all. :shifty:
You can try the nut/screw thing on the top or side, I haven't had much luck with it though.
Yeah, best to leave that alone as messing with it usually will do more harm than good. I've seen 'em adjusted to far causing the box to bind, not a good thing.
If you feel you simply must screw with it...1/2 to mayyybe 1 turn is all you can safely turn it and that's usually not enough to make a noticable difference. I'd replace it with a firm feel unit and be done.
