71dusterman
I would tack instead of epoxy. A tack is less likely to let go and cleaning an oily area is not a sure thing for good adhesion.
I definitely prefer the idea of welding. In this case, I think a tack to secure it would be plenty but I like the idea of epoxy for sealing purposes. I want as much oil to the arms as I can facilitate; they've got a rough life. Once finished the entire hatchet job will be encapsulated by a rocker stand, so even if adhesion is less than ideal nothing can really move. Oil pressure would be trying to push it out, but the rocker stand would bar such movement. I'll likely end up with a combination of the small tack to retain, using epoxy as filler (equate to silicone or bondo, it's just as dodgy as either) to stem oil flow past the repaired area.I would tack instead of epoxy. A tack is less likely to let go and cleaning an oily area is not a sure thing for good adhesion.
Ideally, I'd ream the ends of the shafts far enough to tap them for a pipe plug where I have the plugs currently located. Unfortunately, that's a bit beyond the tooling I have available to me, so doubling up or even epoxying them in place is definitely worth considering. They're not really retrievable down that far, so taking them out at some point in the future probably isn't going to happen anyhow.ok just going to spitball this, but...would it not be benificial to use a solid plug or even double up plugs?
I found a set of NOS Mopar Performance ones on eBay and bought those, but I'd still like to have a few extra sets. If I do, I've no idea where they are.
Well, when it comes to vintage Mopar parts, I'd rather err on the side of "too many" than not have what I need. However, in this case I did actually look before I started getting too crazy with my search. Hughes Engines sells them, but @ $7 each plus shipping, I'll pass. I didn't see a set offered. I know they're not making them, so I just need to find out whose parts they're using."Holy crap I have 4 set's of those?"![]()
As I've mentioned previously I had nothing to do with the construction of the shortblock beyond replacing a damaged piston. It's entirely possible the engine was freshened with only a quick manual cleaning of the block, not paying attention to the water jackets.id bet the rust was from some random shit left in the block down in between the cyls unless you scrubed the livving shit out of it even then its rare to get "all" of it..and no amount of time in the hot tank ever seems to get it all
I don't know Whit, but he's my kind of guy--especially considering that his exhaust was likely a bunch louder than mine. With the burnt pushrods, I damned well should've been able to hear the out-of-whack lash, but until the valve covers were off it wasn't evident. Stretch mentioned that he didn't think the whine was all that noticeable, but then justified that statement with "But I haven't spent much time around it without open headers, either." That's a fair statement.Many of the old Cascar series racers ran gear drives on their road course engines. I remember Whit saying how he hated setting them up, and how they hid the rest of the vital-to-the-driver-engine-and-drivetrain noises while being raced.
