340EH
going for hernia surgery on the 18th trying to get the car home before the big day. The rear axle is under the fury we are waiting for correct u bolts. the spring packs in the Fury are quite large he said 8 leafs? can't remember that but when stock she did sit quite "Proud" plus there was a hitch so who knows. Still to be done, upper support across the rad has to be remade to fit around the Dak rad. finish welding the mount tabs for the front subframe U bolts installed and column reconnected so I can steer the beast.
My homework is to reassemble the dist out of the Dart so I can move it back out of the Garage. My buddy Ted came over and helped me get the Dart running so we could get the Fury out of the garage but he said the dist was stuck on full advance and I should disassemble and check out the advance weights. after disassembling every thing seems fine the weights have one light spring and the slotted heavier spring. The weights move freely but I am curious how the vac canister goes back in. The lever arm for the VA was sandwiched in between the base plate and the plate with the pickup (electronic) on it. it was kind of tricky to get it out and I'm pretty sure I did not use the correct method to get it out. I'm sure I haven't damaged any of the parts but is there a trick to put this sucker back together does anyone have an exploded view of an electronic vac advance dist?
Thanks agan for all your input and knowledge.
