- I thumped the starter a couple of times and it turned over maybe once then CLICK again.
- I jumped it at the relay CLICK - not the relay
- I recently replaced the positive battery cable and yesterday put a different newer, cleaner negative cable on it but CLICK - not the wiring
- I jumped it at the starter CLICK
So the only things left to check is that the starter is tight and grounded and the battery cranking amps. I doubt the starter is loose since it was working before, and since it was cranking until it wasn't, I'm skeptical the battery failed out of the blue. (It would definitely be easier to swap the battery into the A12 and see if it cranks over as a test than to haul it out to the parts store to test it.)
I've been thinking about what it would take to lift the engine up high enough to get to the starter. That means removing the headers, and I'm not sure I'll be able to get the headers back on by myself with the engine in place and I'm not sure the engine will go back in with them bolted on. So I'm looking at alternatives for the headers to avoid half the fight by not putting those poor fitting tubes back on it.
Schumacher headers don't trap the starter, and can almost be stuffed in with the engine installed, but they're out of stock. TTI shorties say you have to lift the engine up an inch and a half to get the driver's side in so that's doable, but they don't say if they trap the starter, but it does say I can install a 4-speed if I use a $400 RobbMc starter. (using the 4-speed is part of the appeal of changing to a small block).
I've reached out to a guy who HAD a pair of Schumachers for sale, unused but not really discounted, but he quit talking to me before he gave me a shipping cost so I'm trying to find out where those stand. I don't know if the TTIs are available or not and they only sell through dealers so I'm holding off bugging anyone about availability on those until I know about the Schumachers. Plus, it's Sunday.
BTW I always said the engine is sitting high in the front, and I found proof. Both Schumacher and
T-D conversion mounts require trimming the motor mount on the k-frame for oil pump clearance. Mine is not trimmed and has about an inch clearance. If I go through this header hell, I'm going to replace the ears with one conversion kit or the other.
ETA: the battery just passed a 700 CCA test at Advance Auto. So it's the starter gone bad.
