b-body-bob
I changed the vac gauge for a cheap mity vac gadget, so it's got a release on it. With the engine running the needle barely moves, and if it wasn't for the release, you could convince yourself it's not moving at all. I could connect the vac advance to manifold vacuum and it wouldn't make one bit of difference. The gauge is connected to manifold vac that is open to the manifold with no blockage or hose problems. I checked because I was gob smacked at how little vacuum it has.
The car idles better than it ever has though, so I guess it's got almost exactly how much vac it needs to feed itself. FWIW I've got the idle speed just under 1k with the engine warm.
Revving it up I saw it shoot up to 20. No idea about the RPM because I can't see the vac and the tach at the same time. With the idle vacuum such as it is, it doesn't really matter.
I bumped the initial advance to 30. The idle speed increased, the vacuum didn't. I didn't keep going. I didn't want to start chasing ghosts caused by manually advancing the timing that increases the idle speed causing the mechanical advance to advance the timing more, then when I decrease the idle speed it slows the mechanical advance and retards the timing. I'm unsure how to take that out of the equation.
I don't even like thinking about the hell that could be wrong (rings/valves/cracked head) but at the same time I don't know what could cause this and not have other symptoms. I'm kind of left with it being a symptom of the camshaft and a need to dial that in. I'll say it one more time - if I have to pull this motor it's not going back in. I would like to get it running good enough to get some ice cream before replacing all the parts that I haven't already replaced ...
