69.5CUDA
Blah Blah Blah
Looks great Cow!!! Wishing I had a 70's-80's Dodge crew cab! :2thumbs:
Although a '73-91 3/4, 4X4 Suburban has been crossing my mind quite a bit. :hmmm:
you need a ramcharger tub and a 4dr cab..and little else....the frame idealy needs to be a 4dr short box..but..its going to be a little too long in the wheel base by about 10 inches?(stock RC is 106 and a stock short base is 115 i think)...well this is if you do it the way the factory would have....IE drill out the spot welds and re-align the parts..especialy the cab striker riser panel of the RC..you fit this in place of the cab riser..the only actual "custom" parts in the end would be a slightly modified frame, and the roof....which personaly i would use 2 RC roofs as they will graft together better..but you slice it right at the rain gutter to graft into the 4dr cab front half......yeah shure you could just weld a bed to a cab and hope it holds but i dont see it holding well
