Disassembling the pedals with the dash in place isn't a task to take lightly.
You have to remove that side brace to get the clutch pedal out. Somehow that ended up turned and caught on the pedal/OC pin and I like to never got that thing out of there.
After all that, there's really nothing wrong with it. The bearings are dry, the bushings aren't worn out and the whole thing was kind of "gummy" from old grease I guess but otherwise it would've been fine to just leave it alone.
It's a hell of a lot easier to do what you did by just dropping the whole pedal assembly out. Well, OK, it's just as easy with the pedals in the car, assuming the entire dash structure has been removed, but few ever reach that state of disassembly. The only part of pedal service I prefer to do in the car is removing the OC spring. With the pedals on the bench/floor, that can be exciting.
Has anyone used one of these and can explain how they install?
CS-PPA CLUTCH SAFTEY SWITCH LOOP & PUSH PIN A-BODY GOOD USED
Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
Worst case I'll call Brewer's and ask before ordering.
First and foremost: Do you have a clutch safety switch? If so do you intend to use it? If you answered no to the first question, you might want to price out a switch before you get too excited. If you answered yes to both, you'd do well to test it now before you get too invested.
That link connects the actuating arm of the switch to the pedal. The straight end goes through the hole on the arm, while the loop end gets pinned to the pedal using the supplied push pin. This can be installed in-car without too much difficulty. Be forewarned: Those links do not suffer bending well. They'd just as soon break as flex. It's strong wire, but it seems to be hardened. I found one in the garage when I was doing mine, and thought, "I'll just shorten it with a li'l bend here and another there." *SNAP* "OK, I'll just make one from a brake-shoe spring," which was neither more enjoyable nor more forgiving.
When the pedal is down, it grounds the switch wire through the switch body, completing the ground circuit for the starter relay. Prior to 1970, when people were apparently a little smarter, Chryslers didn't even have clutch safety switches. There wasn't even a provision for it on the starter relay (manual and automatic used different relays). If you don't want to bother with the nonsense, you can simply ground that terminal on the starter relay to its mounting bracket. Of course, the car will attempt to start with the clutch engaged if you don't have the presence of mind to push the pedal.
Curiously, despite being an automatic my '69 Valiant had a manual-trans starter relay in it. I can only assume it was replaced at some point, but I suppose it's possible the factory installed the wrong one and just left the NSS ground wire hanging. Of course, moron that I am, I found an NOS clutch switch and installed it, only to later discover the car wouldn't have had one originally anyhow. I also discovered my pedals already had a clutch switch on them, since they came from a later car. I will not go through all this again on the '68; it can stay as-is.
