beeper*71
This space for rent
Last fall I purchased a used Mueller Climatrol shop furnace for my garage. This thing is built like a tank with cast iron burners and heat exchanger and was probably built back in the 60's or 70's.
I have been pecking away at installing it and today it was ready to be fired up. It's set up to burn LP and once I finally got all the air purged from the lines I was able to get the pilot lit but I had to hold the button for nearly 5 minutes before it would remain lit.
Once the pilot was going on it's own I turned the controller valve on and flipped on the power and baby we got heat! :giggedy:
Well at least for awhile anyway. When the garage warmed up and the thermostat kicked off that was it, the pilot light had gone out and shut it down...damn. I relit the pilot and after another long period of time it stayed lit only to go out again as soon as I turned on the valve. Tried again and it stayed on once the valve was turned on only to go out again soon as I turned on the power. After that several attempts to re-light the pilot failed as it would go out as soon as the button was released and I finally gave up.
The fella I bought it from said he had the controller checked over by a service professional and it was good to go but he never got around to installing the furnace as his plans had changed so he put it up for sale.The controller looks as if it might be newer than the furnace itself.
It seems to me like the controller is not recognizing the pilot light. Could the probe that is exposed to the pilot flame be bad? Looks like it's been there since day one as the fitting holding it in is very much rusted and the tip of the probe looks a little melted.
Am I on the right track here or is the supposedly good controller the problem?
Any help would be appreciated.
