Fender top directional
Will the OEM 68 bulbs fit into the Asp-olare lenses?
Nope....the 68 bulbs are tiny little things. You's probably need two pairs of glasses to see the little buggers. :D The later turn signals use a lot bigger bulb. Pretty sure the bulb is the same style that is used in teh dash lights...push in blade style with small wires on the outside...can't recall the number.
the bulbs I showed above are 330's , the dash bulbs are 194's ( push in type)
I will have to dig out my spare set of those turnsignals and double check...sure they use the 194's.
