Dodgedifferent2 goes hotroddin
Side project. Took a harbour freight bead roller and made it decorative, beefed it up and added a motor.
Waiting for a drum switch that's stuck with the striking canada postal workers.
Started doing some body work today. Had to replace the wheel wells. It's just the beginning of the craziness. ATTACH=CONFIG]20548[/ATTACH]
so hows the motor work as far as speed/torque goes? ive been considering doing something like that myself having the exact same roller as well as some custom milled dies
its nice to be able to have half a body on the bench to work on aint it....my lloyd started life being able to do that lol
Well, I'll be... you went for the nailie. That excites me. :dance: You want me to keep an eye open for one of the GM bellhousings with the half-833 bolt pattern? I see 'em at nearly every show.
Nice work thus far, DD2. I'm very impressed with the skill you've shown us already.
Door shortening to match the previous owners chop20190515_123230.jpgIMG_20190515_144217_314.jpg
slow n tedious doesnt begin to describe this kind of work, measure a million times think it thru then stitch for a day
Wait.. you can bolt a nailhead to a mopar 4 speed? I turned one down because I would be stuck with Buick’s two speed slush box, or the expensive switch pitch
So here is where I am at now.
I pushed the dakota on the backburner till its cooler outside to do some sandblasting. Aka winter
Have the body on the chassis and lining things up to where I want them.
As for the nailhead to a833 it's a whole nother job.
I have to custom make a spacer between the bell and engine. I have an adapter between the bell and trans.
The fun part will be seeing who will get me a clutch to work with the nailhead flywheel and splines on trans. Likely end up being a custom piece from someone. Starter will also be some more fun.
Once I get the body on then the plan is to make some lake style headers that go under chassis. As I am hoping to do a custom fuel injection 6 stromberg carb style deal on the top side.
I seem to like day dreams that may turn into nightmares.
There are a few ways to do it. There are factory GM (Chevrolet) bellhousings from trucks that are half A833 bolt pattern, half Borg-Warner (Sagi-Not/Munchie). A GM main case could be used, or the bell could be machined for the remaing two holes.
Another way is conversion bells that were fairly common in the '60s & '70s. I see 'em at swap meets now & then. They'll have a BOP, Chevy, Ford, or AMC block pattern with an A833 trans pattern and pilot diameter (usually for the large bearing retainer).
There were also bellhousing and transmission adapters; I saw one to put an 833 directly on a GM bell on eBay last week, but I can't find it now. Current eBay item 113944936946 is a full bellhousing adapter that claims to mate a Mopar bellhousing to a GM pattern block, but the starter appears to be on the wrong side and it has an OE-style GM number, so I'd investigate further prior to pulling the trigger... but it's a reasonable facsimile of the type of adapter I've seen.
Cool project!
Hey DD, your tires are on backwards...💃🕺
Hahaha...I was just going to post that as well. 😄
But super cool project....I'd love to get something that old but my 6'8" and size 14 feet make darn near impossible to comfortably squeeze into one, I've tried in a few cars at car shows. ;)
