dodgedifferent2
hung like a stud field mouse and
whos there?
i was tinkering away and driving the dart all last week when all of a sudden a knock started. At first i thought i may have wiped a lobe on the camshaft:doh:
but i noticed the header was touching the frame so i reworked the pipes to clear the frame.
I started up the 340 again only to hear the knock so i decided to take off the intake to check the camshaft. Everything looks awesome under there so i was somewhat happy :giggedy:
With the view from a local ex dirt track racer who built his own engines. He suggested i drop the oil pan again.
I did and i found all kinds of metal flakes in the bottom of the oil pan :doh:
Now the scary headaches begin :doh:
I am planning to pull the engine out of the dart so i can work on the engine stand instead of on my back.
I noticed the connecting rods that are stamped with the piston number and two of them seemed to be swapped. Number 4 is in the #1 position and the #1 is in the #4 spot. Could this be the culprit? or is that just minor?
now the day dream (sometimes turn into nightmares) Depending how the crank looks should i just go 416 and use the heads i have till another day? or replace all bearings and keep it 340? Have i messed up a connecting rod?
I have only drove the 340 for about 40 miles:hmmm: and whatever restoman ran it for.
I know i have some digging to do so see what is up. (will come later)
what is your thoughts and views with a 340 vs 416 or 372 and mostly stock J heads with 2.02 intake and 1.6 exhaust
