I’m working on the 2014 RAM.
Trying to take the front passenger seat out.
All but one anchor bolt came loose without issue.
The back, inboard bolt turned with a breaker bar. Then I put an impact on it.
It came out about a half, maybe three quarters of an inch and then stopped.
Now it won’t even go back in.
I’ve soaked it a few times with penetrating stuffs of all kinds, starting with PB Blaster.
I’ve banged on it with a hammer to loosen any corrosion, but that seems unlikely to be the issue as it started turning without issue, initially.
I can only guess that the bolt was bent. Maybe?
I’m afraid to go too hard on it with the breaker bar for fear of actually breaking it.
Other than the heat wrench, I can’t think of anything else to try.
The heat wrench is kinda out of the question as there is no access to the bottom of the bolt from under the truck. The hole seems to land under some kind of duct.
Heating it from the top seems like a bad idea. I can’t get heat down on the shaft of the bolt without lighting the carpet on fire. I think.
So, any tips or tricks?
My only other thought is bigger impact wrench.
I’m not even sure the torque on mine.
