I got this from the original owner of my Hatchet Job 360. This stuff is all from his mud-drag days, but there's a lot of good stuff in here that would work for hot rods, too. He did not send me pictures of anything; for those you'll have to contact him. If anyone's seriously interested in any of this stuff they can PM me for his contact information, which will be the extent of my involvement. Mark's a straight shooter, I will tell you that. He did not skimp on things.
Motors
1. 383 Big Block Chrysler – Block No. 11-24-65 / 2468130-6, Wieend Team G intake, holley valve cover, adjustable rockers, big valves in heads, mild porting, all direct connection internal parts. $1500.00
2. 440 Block – Block No. 1-24-74 / 3698880-440-8, Bored & Line Bored. $500.00
3. 1972 400 Truck Engine – Complete - $300.00
4. 360 Block ONLY – Block No. 1-18-78 / 4006830-360-5 - $100.00
5. 1979 360 Complete - $200.00
6. 474 Big Block Chrysler Stroker, M1 Intake w/dominator adapter, Eagle Rods, Ross Pistons, Steel 440 Crank, Ultradyne .640 lift Cam, 2.14 / 1.81 Ferrea Valves in heads, Stage 2 porting adjustable crane Rockers, Aluminum Water Pump & Housing, MSD Pro Billet Distributor, Engine was build by Muscle Motors - $4000.00
Tires – ALL Tires have Never seen pavement
1. (2) 36 x 12.5-15 TSL Super Swampers $300.00/pair
2. (2) 35 x 14.5 – 15 Swamper Boggers (New) $600.00/pair
3. (2) 16/35-15LT Swamper Boggers - $300.00/pair
4. (2) 16/35 – 15LT CUT Swamper Boggers - $500.00/pair
5. (4) 15 x 10 Aluminum wheels w/beadlocks & removable centers, comes w/2 different centers. $300.00/all
Misc
1. Dana 44 w/410 Gears w/new rotors & calipers – 79 Ram Charger – Full time 4x4
2. 9-1/4 Rear end w/disc brakes & 410 gears – 79 Ram Charger
3. 9-1/4 Rear end – 79 Ram Charger
4. 727 Big Block 4x4 tranny w/trans brake – fresh rebuild - $500.00
5. 1050 Dominator carb w/ quick change jet bowls (used) - $500.00
6. 650 Holley spread bore / elec choke / vacuum secondaries, p/n 0-80555C (used) - $200.00
7. 750 Holley double pumper / manual choke / with quick change jet float bowls, square bore (used) $ 300.00
8. 600 Carb, List # 6231 Square bore, vacuum secondary, electric choke (used) $100.00
9. 50cc accelerator float bowl kit $40.00
10. Dynagear # 78104 Timming Gear set, New True Roller – Big Block Dodge $40.00
11. ARP 145-6002 BB Rod Bolt Kit (new) $40.00
12. ARP 250-3005 Ford 9” Stud Kit (new) (Qty. 2) $15.00/EA
13. ARP 200-2906 Chevy Flex Plate Bolts (new) $10.00
14. MSD Soft Touch Rev Controll # 8728 (used) $50.00
15. MSD Pro Power Coil #8201 (new) $75.00
16. MSD RPM Selector Switch #8670 (new) $40.00
17. MSD RPM Selector Switch #8671 (new) $40.00
18. MSD RPM Selector Switch #8671 (used) $20.00
19. MOROSO #25900 Crank Kit, Evac Kit (new) $40.00
20. B & M Pro Stick Shifter #80701 (used) $100.00
21. B & M Air Shifter Solenoid & Tank / MSD #8728 RPM Switch for B & M Shifters) used / CTN-SA4000 - $75.00
22. Autometer #5891, Phantom Volt Gauge - new $40.00
23. Autometer #5857, Phantom Trans Temp – new $50.00
24. Autometer #5828, Phantom Nitrous Press – new $75.00
25. MSD #8202 Coil - $25.00
26. MSD # 8213 Coil mount - $5.00
27. GER 9” Puller Converter for 727 Torqueflight Tranny - $300.00
Motors
Misc
