Two 'n' the pink
Where's @Jester when we need him the most?
@Stretch and I undertook the recovery my latest project this morning, a 1970 Swinger 340/4-speed painted that rarest of hues, Panther Pink (code M3). It went far better than expected, with the majority of the several hours spent being just talkin' cars and checking out all the other cool stuff the seller still has lying around. Unfortunately, the pole ban containing all this stuff isn't powered, so there's very little light and even flash photography's kind of useless. He still has a '71 Swinger, a '68 Barracuda fastback which I believe is a Formula S (I didn't look at it today), a '74 360/4-speed Road Runner, the 1966 Valiant Signet 273HP/4-speed formerly owned by a friend that was in my possession for a short time back in '03, a '65 Barracuda 4-speed car (now with a 340), and more hip first-generation Javelins than you can shake a stick at. Every one's a project and none of them are for sale. Prying the pink car out of his possession took over three years.
The seller's son, Mike, had his late-model race car out of the way before we got there, which gave us a straight shot out of the barn. That was important, since the steering column is locked on the Swinger and he didn't have any keys. Amazingly, all four tires took air, and held long enough to get the car on the trailer. Three are still holding air now, 12 hours later. We pushed the car into winch range while Mike heaved the front of the car sideways a couple of times to influence its direction a tad. It was on the trailer and strapped down in no time.
The interior was chock full of parts, not all from this car. Who knew an E-body column would fit into an A-body? I need to find a column; of course it's 1970 only due to the reverse-gear column interlock.
Hello, beautiful. The original hood scoops were still in the car, sitting atop one of the seats. They still show pink paint in some areas. The original bezels are missing (so far) but I have a pair of nice ones I bought at a swap meet last year. Beneath the seat, the original driver's-side door is partially visible.
Safely deposited in my back yard, I immediately grabbed the now-black scoops and found that miraculously, not one of the mounting studs is broken or pulled. I immedately "installed" them, because that's what one does. They're just resting in place because if there's hardware, I've yet to find it.
I then commenced to automotive archeology, discovering what lies beneath the dirt. I pulled two complete back seats out of there, one obviously from the parts car and one from a '70 with a white Custom/GT interior:
There were also white door panels from the Custom/GT interior:
When first I saw this car in 2001, it had the white GT bucket-seat interior installed. Since that day, I've believed the car was built that way. Had that been the case, this car would be one of only two known so built. Unfortunately the data tag says low-line black bench-seat interior, which makes me sad. I believe the cheap black bench makes it one of around 14 or so, but the reason I'm sad is because the white GT interior would be so beautiful on this car.
Moving right along, as I excavated further I found a grille, which probably wasn't broken when it went in there, but is now:
There was another grille, which I believe is the original, stuffed in the trunk. It's even more broken than the first. Deeper toward the floor I found these lying in a stack on the floor, all 1970 but two were painted black over the light argent:
The original LH door as mentioned previously, with the original mirror still attached:
Not sure what was happening with the blue paint, but the factory door decal remains, clear as a bell (digitally altered sequence) over pink paint:
Digging further I found two back windows, neither original to the car (there are glass remnants on the package tray). One's tinted, probably from the parts car, and the other is not. Both are in excellent condition. I don't believe this car had tinted glass. Fitting for a pink car, it's a bit of a stripper.
Anyone need a '70 ECS, '71-up fuel cap in factory Vitamin C paint? I've got a spare.
The door was covering a mystery shifter. What exactly this is escapes me. It's definitely a '75-'80 A/F-body handle in a Competition Plus mechanism, but the levers are all straight (and rather long). A/F-body shifters have a backward hook to the reverse lever. It's a bayonet (push-in) stick, but the body is factory-equipped for overstop bolts--the holes were clearly punched, not drilled, through the main body.
Also hidden by the door were an absolutely-flawless set of quarter-panel end caps from the parts car. I don't think I need these, but won't know until I get the originals off.
The original steering wheel was one of the treasures found in the trunk. Back in '01, this car had a woodgrain Rim-Blow wheel in it, which was not available in a '70 A-body that I can find. However, the E-body steering column might explain that. This one jives to the data tag, but I'm gonna be honest: I'll probably put a deluxe (partial horn-ring) wheel in this car. This wheel and the '70 A-body Rim Blow--which is what's in the parts car--are just too ugly, even in perfect condition. I'll keep this around, but I'm not likely to use it.
The '70 bench seat that I'll probably use is out of the parts car. If you look closely, you can see the bumpers from that car beneath it. Those will get sent to be straightened and rechromed. That little bucket contains all the original fender hardware. Also, lookit that floor!
Too bad someone hacked the floor in the shifter area decades ago. Sadness. If I had to guess, it had an E-body transmission and shifter in it at some point. That's right where the long-tail shifter would be, and it would also jive with the GT buckets that were in the car 23 years ago (there was no transmission in it then). Thankfully, the parts car has a virtually flawless floor.
The original cluster bezel is trashed, and I need another worthless two-spoke E-body wheel like I need an extra hole in my head. I've no idea what the little switch panel did, but next to it you can see a factory map light switch. The trip odometer reading 666 wasn't a great omen. 😦
Minor victory: The reset cable still works! I rolled it back to 000. The dash structure needs to come out for refinishing. No biggie; the windshield's broken anyhow and I want it out when it goes for paint. The parts car has a good winshield, but it's tinted (AC car). I don't think this one is.
The welded washer indicates this is a 340 K-member, likely the original. Forward of that is the factory swaybar.
I'll post more later, and I still need to get photos of the parts car. That car has some excellent metal on it, and will likely donate its floor, outer wheelhouses, lower core support and side panels, etc. to this car. It had a perfect LH quarter, but they cut it like morons so I'm not sure if my body guy will want to work with it.
Pink with white guts holy jezum crow that would be stunning. Never imagined anything like it but wow.
Wouldn't it?! It was in similar shape to what it is now back in '01, and despite being a pink 4-speed car, what really drove me over the edge was that white interior in it--my belief being that it was original along with a white top and tail.
Govier did his thing with the car 25 years ago. The seller lost that paperwork in a move, but I spoke with Diane at GTS. They have the VIN on file and she said she'd get me all the information. I'm sure I'll have to buy it, which is fine, but it can't happen quickly enough when you've got "new car syndrome" like I currently have. Anyhow, the reason I bring it up is because Stretch thinks I should just do the white interior anyhow because it would be f__king gorgeous, whereas my man Pete says stick to the fender tag. I'm really struggling with that decision. Perhaps the paperwork will help me decide. Honestly, the fact that the buckets have vanished sways me toward original, since core seats will probably set me back another grand. Legendary doesn't even offer upholstery for the white GT interior, so add a custom fee there.
I almost forgot the most important bits of all!
Despite not having the numbers engine block, little stuff like this still excites me. Correct, date-coded wiper motor? Yes!
The weather was downright crappy today so I didn't get any more photos. The trunk is chock full o' goodies, including the numbers transmission, seatbelts, and a bunch of other crap through which I need to sort.
lemmy ask this doc..if you had a white gt gut in front of you and the OE gut..which would you put in it
personaly id run the white gt gut..mostly cause i adore the gt gut in ANY color..but white on pink YES
as for that dash bezzle..IMO its not trashed, as replacing the cut out section is actualy VERY easy...especialy if youve got a broken dash to steal a section from...so save it if nothing else..hell i might have the chunk to fix it..just dont ask me to look for it this year....next year ill have the space to spread everything out and re-sort/pack and display stuff
lemmy ask you about seats..if you wanted A-body buckets are the 70 seats unique?...i ask as ive got a pile of cores.........i had a set of gt seats with the lil chrome button/badge thingys..dunno if i still do..
side note i found out b body headrest parts are identical to a-body...also i know somewhere ive got green headrests
oh yeah, refresh my brain arnt those scoops the same ones used on the 69 1/2?..someone once told me the dart ones are longer?
ive seen and owned that shifter before...it was on a OD trans in the 68 i was TOLD it was a 3spd shifter stuck in a 4spd base?...no clue on it...i cut it and altered it to fit under a automatic console with the auto "square" cut out of it..worked pretty good too
If it wasn't such a high-value car, I'd run the white. However, if I have to sell it, the additional floor holes for buckets and the wrong interior may hurt the value of the car. It's hard to say, because the pink/triple white would be a knockout--I know, I've seen it on this car, crappy as it looked at the time.
The trick with the white interior is that it was only available on the Custom/GT interior, and even then the dealer literature was a bit confusing as to its availability. Not many were ordered, period. One of the reasons the previous owner thought the car was one of two was because there's only one known M3 Swinger 340/4-speed with a white interior. The basic bench interior was not available in white, nor was the deluxe interior.
I'm sure I can fix it to driver level, but the repaired area would be very hard to conceal. It has to be perfect. I'd rather find an damaged one and have it restored than try to make something work that's good, but not exceptional.
The seats are '70-specific. '71 can be made to work but the hinge covers are '70 only. They're high-back buckets with no chrome on them. In '72 they went to a different seat release mechanism.
I have a set of black ones currently sitting in the '68 Valiant on the '70 Dart deluxe bench I bought for that car. They're not very nice. I also have a pair of green ones that came with the Dart that ain't much better. The headrests are not easily reupholstered, if it's even possible. I don't think it is.
They are different. These are the same scoops used on 1969-'70 Super Bees with fresh-air hoods. They're probably a foot longer than the '69½ scoops and a couple of inches wider. These are fiberglass, while the 'Cuda scoops are die-cast metal (zinc or pot metal). The 'Cuda scoops reappeared as an option on either the Duster or Dart Sport around '74, but I've literally never seen one with them in person.
The handle is definitely '75-up A and F-body. There was a lot going on in those years. Despite using a Hurst shifter, the handle wasn't stamped because it was only used behind overdrive transmissions, which weren't available in performance cars. Starting in '76 or '77, the exact-same shifter had "HURST" stamped in the sides for use in the Volare Road Runner and Aspen R/T. Chrysler also used ITM shifters during this era, which are a dollar-store copy of the Hurst design rather than the crappy reverse-trigger unit used from '66-'68. Everything from the ITM shifter looks like a Hurst, but nothing interchanges. Internally, it's a completely different unit and very obviously made as inexpensively as possible. GM used ITM shifters during the musclecar era, and they're the same crappy design. Based on how tight it is, I seriously doubt that handle's ever been out of the shifter mechanism.
The problem is with the mechanism itself. The 1-2 and 3-4 levers are about an inch longer than any other A/B-body shifter I've seen except the '70 B-body Pistol Grip, which was also a bayonet shifter. However, every A/B and F-body shifter I've seen has a rearward curve to the reverse lever, with the exception of the aftermarket overdrive shifter. That shifter used a bolt-in handle and rod bushings. This thing's definitely OE quality, but has punched holes for stop bolts that were never present on OE bayonet-style shifters. I almost think it's a parts-counter item, maybe even a Direct Connection part. Those long-ass levers would make for a very short throw.
I was asking questions about my shifter woes and someone noticed that mine has a stop bolt in the back side but not in the front. Maybe they were going for the best of both worlds :D
Boy Sammy Hagar is a disgusting M-Fer isn't he? Watch, you'll see it.
I don't need to watch. Sammy's been disgusting me for decades.
as per that brocher i have those bench headrests in...green
on the floor holes..didnt you say it had buckets in it at one point?..ie..holes exist soooooo
those seats remind me of the seats that were in my ramcharger that i could never ID, weird blue units..chryco seats but ones id NEVER seen before or since...they ended up in my a108
its a shame the 70 darts got such ugly seats..the 69 gt seats would be drop dead sexy in it, the gt seat patterns imo were BETTER than the barracudas including the door cards, something about it i just dig...mind you personal fav has been the armrest bench used in the 67-9 fish..i thinkk the darts got em too?>
well be gentle with that bezzle, if nothing else i might be willing to repair and send back at some point..i learned a few tricks about cutting and splicing them to a point where once panted its impossible to tell....well anything short of stamped letters being mangled....and ive even tried shaving those off and moving them over...i have moved over whole heater control sections pretty easily..is anything else wrong with it beyond the radio hack?
