I’m starting to pretend to make plans to get back to work on the Charher.
I was thinking I’d just need a rebuild kit for the rear end, but while trying to figure out which size pinion bearing I need I saw this.
So, I’m guessing I need to look at a ring and pinion set, too.
Not the greatest picture, but that leading edge of the pinion is chewed up on every tooth.
It’s a 489 case. Is there a way to determine which pinion is in there without taking it apart? Rebuild kits spec the gear size. So I want to know what to order.
or if I’m getting a new one anyway, can I put it in whatever I want? If so, I’m guessing the thicker, the better?
So, they list ring and pinion sets and spec the number of splines but not the gear size. Frustrating.
