Have you scraping off that shiney paint where your grounds are going? Only takes one bad one and you'll be chasing all kinds of gremlins.
So far I think I got all the ones I hooked up clean, but there may be more under the dash, still a bunch a spagetti hangin under there! :toot: Rich.
Got almost everyting on the exterior buffed out, pass side from body line down needs the second swirl remover job & wax, still have to deal with all the seams, the door jambs & such ,but it's lookin much better! :giggedy: Rich.
Was having a lot of trouble getting the swirl marks out with the buffer, so I got an orbital waxer, best 24 bucks I ever spent on the car, I LOVE this thing used it & maquires swirl remover then yellow wax, mind you I still have scratches & the other defects to touch up, but this got out most of the swirls & some of the lighter scratches! :)
This is the area I'm most proud of, only some tiny defects & runs on the edges of which I got most out, but the roof took the least work & came out the best!:bravo:
So I moved my phoney turf over to get me out of the mud while I run the drainage pipe, now she's back on the turf! Tomorrow I hope to pick up the trunk lock & get that all working, maybe put a few more dodads on!;) Rich.
Do you remeber where each piece of metal is that you welded in? :shifty:
It suuurrre is lookin' sweet, be proud, be verrrry proud. ;)
Thanks guys, been a long haul & yes I do remember every last one of those pieces, :toot: kinda miss that stage, seemed progress was moving at a better clip, well soon enough if I can't afford to buy the interior this year I may start tearing into the 74! [smilie=2: Don't cost nothin to cut out the rotted metal.I even have some metal left over for patches! 340 bros be ready, I may need my welder back before 2010! :shifty:Rich.
That car looks beautiful sitting in the driveway!!!! Awesome job Rich!!!:bravo::clap: I'm proud to have been a small part of it!
Can't wai't to see the grille and bumper back on. :) The tires still have tread on them, what's up with that?
No burnouts in my driveway, I gotta keep a low profile,2 cars on the dirt, painting & whatnot outside, my business is out of the garage, no extra attention needed here!
Those tires have been sittin for many years,not as rotted as the 73's set but I wouldn't go too far on those, I don't even wanna think about how much there gonna cost me!:eek: Rich.
Start with the bad, no trunk lock at napa, they had the same uiniversal that I couldn't see a way to make it work, so out came the dremmel & I made the hole larger, so I get that all in & go to put the rear side markers & one is upside down, another flaw in the repro skins, the notches in the hole both go towards the front, checked the other car & one goes towards the rear(no left & right markers!) you'd have to look real close, a little wider on top instead of the bottom & the writing is upside down!:doh:front markers went in just fine!
Amazing how dirty the inside of everything got thru the paint process, i've got a lot of cleaning to do!
so liscense light housing is in, after breaking a mounting pin of one, glad I had some extras, little rubber bumpers are on for the plate mount & the plate mount is on & ready. trunk now opens with the key & back cover is on!
