K so we start with no hardener(or is it catalist), using shopline 660 clear,started with medium reducer, went to a faster reducer for the middle coats & back to medium on the last coat.
Light is an issue, but that never stopped me before! First two days it was actually getting dark when I shot the clear, last coat the light was decent.
I was trying to lay it on too thick then, lookin for glass rather then lite(with the rough look)
Air flow, questionable,exhaust fan at rear corner of "tent" & opening at front corner, both about 10' from the car.
eastwood divilbiss cheapie hvlp gun,Gun air & fluid wide open, tried to set the fan with the 6x6 rule compressor at 50lbs with a 50' hose.
Base went on great,no dirt & don't think I ran any of that even down low, clear is killing me or is that killed me, well I'm still typing so only one foot in the grave, the sanding may push the other in!
Started with 2000, then tried some coarse cut buffing, ended up going to 500 on the runs till I got close, then 1000 then 2k, then took it thru 3 buffing stages to see what I had, showed some very fine run lines but some areas are good. on the peel light 1000, then 2000 & the buff seems to be fine. put on 4 coats of clear, but in a few small areas there are paint touchups under only 2 coats, gotta be careful there.
Using mostly 3 4 &6" paint sticks wrapped in the paper, on larger areas a 6" rubber sanding block
for the rounded areas a piece of rubber hose rolled in the paper:huh: seems to work?
I'll pay for my mistakes with many many hours of sanding, I'm learning the hard way! :doh: Rich.
