Too bad I don't like that big ole stripe, it would cover 3 or 4 of my paint defects!
I like the hockey stripe!
I'm not a huge fan of the '73-'74 stripe myself. The same goes for the '72-up Challenger Rallye stripes, which I not only dislike but I positively hate the tacked-on fender "scoops" from which they originate.
RUSTY Cuda said:
one of the bends, she's cocked quite a bit?
It might be cocked because it's forced into that position by being a tick too long or the adjuster at the trans lever being on crooked. Loosen the pinch bolt at the trans lever and get everything squared away up top first, including the linkage rod as square as possible, then worry about the pinch bolt--which you'll need to address to adjust the kickdown properly later anyhow.
RUSTY Cuda said:
OK put the kickdown rod in, loose it stands straight up, when I put the lever to the throttle it pushes it back a bit, now down at the tranny there's a little play in the full open area before it gets to the spring loaded part, like this it's right at the end of the play.
It should not move when connected to the throttle. It needs to slide further back through the adjuster down at the transmission lever. Either that or the kickdown slider is the wrong one, which is entirely possible.
RUSTY Cuda said:
first try with some springs.
You have the kickdown return spring installed properly. That's exactly what that little hole is for, and the spring attaches to the throttle stud like you have it.
Throttle return springs go from the throttle stud to the return-spring bracket. They do not go to the throttle arm. Also, I like a heavy throttle return as much as the next guy, but what you've got shown is total overkill. Chrysler only used one spring for throttle return, then another for kickdown return. I like the security of two myself, as do many. The problem with too much spring is that it's constantly pulling not only on the stud, but by extension on the entire throttle shaft itself. Because of that forward pull on the throttle shaft, it wears the carburetor's throttle-shaft bores, which are unlubricated aluminum... i.e., they wear quickly. Preferably, you want springs that are near "at rest" with the car at idle, meaning the coils are closer together. Several vendors (Holley, Edelbrock, Dorman) offer springs that fit one inside the other. It makes for a neater appearance. I also always hook my two springs oppsite to each other. If one snaps or flies off, it won't take the other with it.
I don't think my springs are quite long enough, but they're much lighter than what you've got. I believe I grabbed 'em off the Dorman rack at work, because they were there. Anyhow, this is what's on my Valiant. You can see how the ends are connected opposite to each other (click on it and it'll enlarge):
RUSTY Cuda said:
The clip doesn't match the 71 manifold retainer.
That clip is supposed to slide over a tab on the valve cover, similar to what's visible just below it in your photo. I believe that wire retainer is slightly further back on a correct '74 360 valve cover, which also has a spark-plug wire loom welded to it where you have a vacuum-amplifier mount.
RUSTY Cuda said:
Ground wire doesn't reach where I hooked up all the others, if I peel back some tape it will
What ground wire is that?
The braided strap is supposed to be on that welded bracket on the firewall just below the voltage regulator.
RUSTY Cuda said:
A/c wires from under the dash, blue & green, they reach the black wire on the compressor or the blower motor, didn't check the diagram yet, but looks like at least the green is the blower motor, blue is right near that cut off white on that is just hanging there?
The green wire is blower motor, blue is AC clutch. I have no idea what that white wire is (it looks yellow in the picture) but it's of no use. There are no white wires in the factory engine-bay wiring diagram. Once again, I suggest you get rid of it. It's only causing confusion.
RUSTY Cuda said:
while I was taking a break the wheel weight caught my eye, is that going to be a problem with the trim rings?
No. The trim rings were designed to clear wheel weights, since wheel weights have been around longer.
Whatever you do about bumpers,
DO NOT buy anything from Bumper Boyz. Their plating work is
garbage. I've seen it peeling within 1-2 years many times over, and in one case it was peeling when the guy got the paper off it after buying it at a show. There's a very good reason they won't sell you the ones they have on display at shows: Someone
else did the work on those.
I bought no-longer-available Goodmark restamped/replated originals for my car, so I haven't any personal experience with reconditioning used ones. It's a shame Goodmark quit doing them; they're freakin' gorgeous. Anyhow, when my friend Kevin restored his '71 Charger almost 30 years ago, he had a place called North Star Bumper in Fond du Lac, WI restamp and rechrome his bumpers. They did a phenomenal job, and weren't expensive. Those bumpers still look good today. I believe
North Star Plating is an offshoot or descendent of North Star Bumper. They appear to be part of LKQ now, which would make sense. They're also in Minnesota, which may be due to LKQ or some kind of environmental concern in WI. They're at least worth a look and maybe getting an
estimate.
Kevin--the same guy--had his '68 Charger bumpers rechromed through Stephens Performance in Alabama last month. That set him back a cool $2,500. But, that's better-than-original, concourse-quality work. I'm sure ol' Ted is doubling his money on it for that reason alone.
