Ok loosened the struts & the shocks & took a few turns off the LCA pivot nut.
Torsion bars are in but it was quite an adventure.
getting the boots on is nasty, I ruined one trying to stretch it with long needle nose pliers, had it almost on & the pliers slipped & put holes in the boot, luckily one old boot was decent & the managed to go on by hand., was able to tap that one into the LCA with a small hammer.
I spun the lca pivot arm so it rested on the adjustment bolt, backed all the way out, luckily that matched up to the grooves in the frame & the bar.
Filled the cavity with grease & put the boot on..........
Wasn't sure about this, the retaining clip was in the groove but way off the bar, I grabbed the bar & it slid back to the pin so I tapped it a few time, clip seems to hold.
On the second bar I went searching for something tapered that was just a tad bigger than the end of the bar, almost cut up one of my rakes, that metal end they put on looked pretty good, but I found a shop vac extension that looked good, not that small at the skinny end, but with it leaning on the ground I was able to force the boot on, greased everything up & slid it right on the bar! This side I had to pound into the lca with a lump hammer.
Clip is closer to the bar, but this one wasn't sliding back easy!
Rube Goldberg does it again!
Snugged up the adjustment bolts, greased the clip side & the bars be in!
Oh yea, I did grease the LCA ends.
