Shit compression would explain the ability to time it excessively. However, as I said, more timing is not always gooder. You might find better results around 32-34° total. It doesn't sound like it would hurt to try, anyhow.
Generally you're most likely to encounter spark knock at low RPM and high load, hence the "Big Fat Friend" method of timing a car.
There's no reason your combo "should shine" at lower RPM. It runs exactly how I would expect it to run, being a small engine with a 340-ish cam, free-breathing heads, and headers... big, stupid fun north of three grand with not much happening below that. Low compression or not, the cam and airflow are what determine the powerband and you've got both in spades, even with an ill-suited intake (which isn't nearly the albatross it would be on a 340 or 360). The less-than-optimal gear/tire combination exacerbates that, and I'll bet a lot of the fun happens once the engine climbs atop the gears. Second gear (Third? Can't remember if it's a crawler first) is probably a laugh bonanza after the upshift. Everything I suggested to increase low-end towing torque would counteract all the giggles you're getting in the upper regions of the tach... you'd be doing four-wheel burnouts instead (no, not really).
