He shows a 9811S with working idle screws and no frozen shafts for $50. Unfortunately, he's
way out of our way for this weekend's road trip... and he won't ship.
Might want to click
here and see what that's all about. Nothing listed online, really, except the chart shows they have electric-choke conversions available... ?
As far as truck manifolds go, you're much better off with the Performer than
any other intake listed. It's designed for small-port heads in the first place and has good velocity at low RPM. That's why they sold a million of 'em... people feel the increased bottom-end torque and think the vehicle's got more power, even though above 2,500-3,000RPM it falls on its face in comparison to even a stocker. Marketing at its finest, that intake. That's why it's great for what you want. Leave the LD-series intakes for something fast. They're counterproductive in this application.
Truth be told, your problem lies in the cylinder heads and pistons. You have no compression. You've got a '72 engine, which had smaller chambers from the factory; as such with the 1.720" compression distance of the pistons you'll find that your flat-tops are more than .100" down the hole at TDC (.102" to be precise, with an exact 9.6" deck height which isn't likely). The key here is this: do the pistons have valve reliefs? If not, they're stock replacements. There's no squeeze with a 71-74cc chamber; my calculations have you at 7.6:1 with 71cc. :doh:
I can't believe I'm going to say this, but for the purposes of a truck I'd suggest finding an '85-up roller-cam 318 (any non-cop M-body, not sure about truck) and grabbing the cylinder heads. You're specifically looking for "302" castings. They've got a small, high-swirl chamber design along with small ports and unfortunately small valves. That being said, they'd boost your compression by at least a point while enhancing cylinder filling down low by virtue of the small ports. Companies such as Aerohead (and several magazines) used to push the 302s hard because they were easy to find and the compression increase really bumps up the seat-of-pants meter. Problem is, at absolute max porting with 2.02"/1.60" exhaust valves, they flow about as well as an as-cast 2.02" J-head.
If you leave them alone, the engine will grunt like a female Russkie weightlifter but fall on its face below 5,000RPM. You takes some, you has to give some. There's more than one way to skin this cat, but what I would consider a minimum would be at least doing a 3-angle valve job, and ask the machinist to do a throat cut (bowl cut, pocket cut) which is a final cut that opens up the "long side" of the valve pocket (bowl) area. Break out the die grinder and smooth in the machined area, as well as the whole bowl area especially including the valve-guide boss. Do not touch the short-side radius, on either the intake or exhaust, other than to just clean up/smooth the port-to-seat transition! Don't be afraid to grind out some of the long-side radius (port roof) to increase the pocket volume in that area, just don't go berserk--it does you no good to have more volume there than you do further up the port toward the intake or exhaust. That introduces port stall, which is something you've already got in spades with a Performer intake bolted to J heads. At the intake manifold surfaces, port-match the openings to the intake (or vise-versa, keep reading). Notice I did
not say "gasket match". Never use a gasket as your template; it's a fool's errand. It causes the mixture to lose velocity at the matched area, then try to regain it inside the cylinder head. Make a nice template from the intake manifold itself, or the head itself in the unlikely event the head openings are larger than the intake's. Just taper it smoothly into the port 1/2" to 3/4". Don't try and reduce the pushrod hump in the port much; there's precious little space there before you're open to the pushrod hole. Leave the main length of the port alone; that's your velocity and will hurt low-RPM cylinder filling. On the exhaust side, since you're using headers anyhow, gasket-match the ports use that as a guide to port all the way to the valve--but again, don't touch the short-side radius (floor) of the port except to smooth it with sandpaper rolls.
Without getting too much into it, maintaining the short-side radius is critical. It's a fluid-dynamics thing, involving boundary layers and such. You want the final approach to/from the valve to be basically as straight as possible, meaning perpendicular to the valve face. That radius helps, a lot.
The above would get you crisp throttle response and good performance into the low-4,000RPM range. The next improvement would be to install 1.60" exhaust valves from a 360 LA during the valve job and gut the exhaust ports to match them. I see no reason to require brand-new valves; if you've got a decent set of used ones that could pass a machinist's inspection those would work since you're doing a valve job anyhow. If you can swing it, have them back-cut, too (this doesn't mean undercutting the stems; your machinist should know the difference). With long-tube, small-primary headers and the small intake ports, working the exhaust side first would really accentuate cylinder filling throughout the RPM spectrum, but particularly in the lower and midrange RPM.
Throwing the 1.88" intakes with the same bowl-port treatment would increase top end a bit, with a small cost in down-low grunt. With the mild cam you've got, I still think you'd be pretty happy overall. Again, don't hog the overall port size. Velocity = torque.
I think with any arrangement, even bone-stock 302 castings freshened, you'd be pretty happy with the results including a noticeable improvement in fuel economy. If you swapped the truck to 3.55 gears, it'd be much happier towing. You might also see an improvement in fuel economy, believe it or not, just because the engine is operating at a better point in its volumetric efficiency range. This seems to have a bigger effect with carburetors than it does with EFI, possibly due to the effects of better atomization and the increased effectiveness of port-wall film. Lugging the engine also encourages fuel puddling. I may be totally wrong about the "whys" but I had a carbureted 6.6L car that got 20+MPG on the highway and ran 12.90s in 100% street trim, with a cruise RPM of ~2,600 at 60MPH (5 over the federal speed limit back then).
All that being said,
I despise 302 heads. They are the most overrated LA head in history, which as mentioned was a marketing thing because they were cheap and easy to find, and shops were selling them out of magazines as fast as they could find 'em. They really have no place on a typical performance build. The only heads that are actually worse for a normal performance build are the abysmal '64-'72 273/318 castings, which have no performance value whatsoever. There are no performance versions of those heads; even the D-Dart used the same shitty castings you'd find on a 2-barrel Belvedere sedan (which is why it was such a spectacular failure). They'll give you a compression bump, yes, but the ports are terrible, the chambers are terrible, they have a low detonation threshold, you name it. For anything other than platinum-restoration purposes, they're not worth even treating to a valve job.
