Maybe he should've........
Foggy
got into editing.
My son that is..........
St. Thomas on Sat. Track was greasy and we had trouble getting hooked, so we stayed off the nitrous.
Enjoy the clip. I laughed all the way through..........
.......:D:D:D
I have since figured out the in-car cam.................
http://www.youtube.com/watch?v=AedaDielqOo
onboard...gopro?..if so ive got one too and have since gotten used to it..but for "general" dry incar use ive got a lil bracket for a normal digital camera
Thanks Doc. I'll pass that on.
Yeah. It's a go pro. Easy to use....... unless you're hobbled with technology deficiencies. Like me.
Next post we should have some in-car clips. I really need that, since my buddy has been
bedridden, and could use the smile...............
theres a few notes i should make about the gopro that can make it a HUGE pain....i have the older non hd unit
are you on the new "HD" unit>?...it has the "good" battery.....if your on the older unit..then expect to change the batterys after every 10 mins of use
do NOT expect to get useable sound from it......there is a hi/lo setting but ive never managed any good sound from mine...expect a "buzz" to replace engine sounds..you might get lucky tho
dont worry about the "flip" mode as you can fix that in editing
i cant say enuf about batterys..10mins MAX or it will just shut itself off every 3 seconds and youll be scratching your head so when in doubt swap em out!!!!...honestly id swap em out before every run or 2..yes...the gopro is just that hard on batterys..even with the best batterys ive only managed 14 mins before dead then you can sometimes squeeze another 3min clip then a 1 min clip ....
ive had mine for a couple years if ya need a lil help ill try and help ya
