44070Swinger
For Sale Complete 6 pack for 383/400****UPDATED****
For Sale Complete 6 pack for 383/400 intake never bolted on, Intake to Aircleaner NO MISSING parts.
Will work great on your 451 to 500 cid stroker engines.
$1,900.00 firm
Fresh 915 HP heads
- cleaned/Mag'ed
- 0.10 thou surfaced
- stage 2 port job
- 2.14 1.88 valves
- machined for positive valve seals
- Manley SS valves
- Crower springs .630 total lift
135lbs @ seat 1.900 installed hight
325lbs @ seat 1.300 compr height
Coil bind @ 1.125
- Comp cams Retainers w/ locks
800.00 OBO
Virgin bore 340 block 500.00
Fresh 360 375+/-hp never fired .1,500.00
New Dougs headers for small block A-body.450.00
A/F-body 4-speed overdrive 150.00
A-body 340 fan shroud "325" pn 200.00
3:91 Sure grip 741 Case 400.00
3:91 Sure grip 489 Case 450.00
2:76 Sure grip 489 Case 250.00
3:55 Open 489 Case 175.00
3:23 Open 489 Case 175.00
Narrowed 8 3/4 NARROWED by Moser Engineering 45in from perch to perch
50 1/4 drum to drum (Richmond 4:11 Suregrip BRAND NEW) large bolt axles Green bearings this whole setup is brand new never driven on !!! Green Bearings 1400.00 ( WILL NOT SEPARATE) for A-body
Large bolt front disk brake setup spindles, upper control arms, caliper brackets, proportioning valve, calipers 275.00
IF THIS STUFF DOESN'T SELL THIS TIME IT's GOIN ON EBAY
raysmopars@gmail.com
$1,900.00 firm
Fresh 915 HP heads
- cleaned/Mag'ed
- stage 2 port job
- 2.14 1.88 valves
- Manley SS valves
Coil bind @ 1.125
800.00 OBO
