Animation Of Operation.
[video]http://www.angellabsllc.com/video/mytengine3d.wmv[/video]
The
MYT (Massive Yet Tiny) Engine by inventor Raphial Morgado, is an internal combustion engine of new design that features multiple firings in one cycle, producing enormous torque in a small area. With 40 times higher power to weight ratio, low parts count, low maintenance, high mechanical efficiency, and low pollution, the MYT™ Engine will benefit airplane, big ship, 18 wheeler, SUV, passenger car, even down to carry on power generator applications. The MYT™ Engine as a pump/compressor also exceeds existing pumps/compressors in providing massive pressure, volume, and flow, all in one unit.
The first prototype model exerts 850 cubic inches of displacement even though the size is only 14" diameter by 14" long, weighing 150 lbs, compared to 3000 lbs for a comparable engine of conventional size capable of that much power output.
As of Spring 2010, the company is presently working on a 6" diameter motor, which could be built inexpensively by machining, without the cost of casting, for its first beta testing units.
They are also considering a geothermal application of the pump/compressor version of the engine.
On the side, as a hobby, Morgado is pursuing an Angel Flight Pack that would enable personal flight for as long as an hour.
http://www.angellabsllc.com/index.html
Mind Blowing.
