Cone type sure-grip
6PK BEE
Cone type sure-grip unit for 8 3/4
$175.
Rebuilt when i bought it last year
HTF do you rebuild the cone types? I have 3 sure grip cone types and 1 clutch type, I was always under the impression that the clutch type was rebuildable and the cone types were not. :hmmm:
Involves a lot more work. New cones are available I believe but the the housing needs to be welded back up and machined back to spec again. I think that's the correct way anyway. It was awhile ago that Dr.Jass told me about it.
The cones are machined down and then shimmed to make up the difference. The early style case bolted together so no welding is required on those. I have one sitting here that the good Dr. jass himself freshened up for me.....someday I may even use it. :)
All Mopar Sure-Grips will interchange; you can put a clutch-type in a 489 (I bought an original that way--late '68) and a Borg-Warner coney will go in a 742. You just need to use the side bearings for the correct case: 742SG side bearings for a clutchy, 489SG side bearings for a coney. This holds true for 741, 657, and 985 cases as well.
Yes, I know how to rebuild a cone-type using all factory parts in factory locations. Some machining is required, but no welding. I have this knowledge, yet for some reason I do not share it. I guess I'm greedy. :D But I do have a machinist set up to do that which I can't, and I think I have parts to do at least 4 or 5 more, and I can find more parts easily enough... they're everywhere. :bwuhaha:
Don't get mad... I told beeper*71 how I did it, and I even told him where the parts can be found--they're as common as gonads. Bamboo slivers under his toenails should jar his memory. [smilie=g:
[I]ALL[/I] factory coneys were two-piece bolt-together affairs, and thusly I can service any of 'em. Some used 5/16" case bolts and others used 3/8" bolts. No prize for guessing which one's stronger.
The Auburn unit is a one-piece case and though I have no reason to believe I couldn't fix one, I've never tried. The factory never used Auburn diffs; the Auburn diff didn't even come out until long after the 8¾" was phased out of production. The Auburn unit is a slightly-modified version of the factory coney, which was manufactured by Borg Warner. Auburn bought the patent from BW in the late '80s, if memory serves. It uses the same side bearings as the factory BW cone-type.
