Slanties use staggered towers, real motors are directly across from each other. You cut and reweld one side and you are V-8in it. Then most any A-body LA exhaust SHOULD fall right in your hole. But if it dont, please blame the boss- because Im a dildo without fresh batteries.[smilie=f:[/quote]
Ahhhhhhhh....I will have to take a look at my existing crossmember but i see what you are saying. Can i re-weld the old motor mount back to the crossmember or do i need 2 v8 motormounts cut off of a different car?
Also maybe you should invest in those rechargable batteries.
