OK guys,
This one baffles me. The rig is my '84 RC 2wd. Was a running/driving rig but the trans was crap and the motor wasnt much better (360-4v), so I swapped in another 360 and rebuilt 727. The motor was a supposed runner in an '80 stepside. Its a '75 360 with a later 4-v swapped on it.
Anyway its all swapped in place, and now it wont fire. I've checked spark, have plenty to the coil wire, verified by moving the dist. back and forth. Also have spark to the coil wires, verified by standing in the enginebay (no radiator or belts on it) and cranking while holding the wire to the valvecover. Has purple-ish blue spark, bright.
I've also checked the rotor phasing, brought it to the TDC mark on the balancer and popped the cap and it was pointing to number six.
I put a charger on the battery and tried to fire it, it popped out the carb so I turned the dist. 180 degrees and cranked it, it made a blub blub sound out the exhaust when I released the key so I threw more fuel at it and nothing. I'm not picking anything up out of the tank quite yet so I'm using gas from a can poured down the carb.
I've changed the ignition box to be sure, the old one had the goo coming out the back, I had a new replacement off another truck that was running and driving. Also changed the dist. to the original out of the old 360, remember it was running and driving.
The only other thing I could think of was that its flooded, even though I held it wide open and open choke and cranked it.
This is driving me bananas! Anyone got any other suggestions?
