beeper*71
This space for rent
1971 Road Runner : N96 Air Grabber car, Hemi Orange, automatic.
The good: New front end, ball-joints, tie-rods, upper/lower control arm bushings (MOOG offset uppers) adjustable drag shocks.
400 block stroked to 451 with steel 440 crank, 440 rods and Ross pistons. Edelbrock aluminum heads with valve springs to match 555 lift Hughes cam. Edelbrock torker intake and 800 CFM Thunder Series carb. Aluminum water pump housing. MSD 6AL and new MP distributor, shorty headers into 2 ½” duals W/H-pipe and 4 Magnaflows. Custom frame rail connectors welded in. New gas tank. 727 trans W/manual valve body, B&M Pro Stick shifter and trans blanket, new driveshaft, fresh sure-grip W/ 3:55 gears. New brakes with fronts upgraded to 11 ¾” disc. Battery mounted in trunk with cut-off switch in rear valance. Wiring upgraded with junction block under hood and late model Nippon Denso alternator. New aluminum wheels, front tires like new, rear’s are Mickey Thompson drag radials. Monster tach, mechanical oil, water, alt gauges and Tuff wheel in interior. Originally column shift car, have shifter and linkage to switch back to stock. Air Grabber parts with exception of under dash switch and air cleaner base are in place and in working order. This is a real N96 car, NOT a clone.
The bad: Needs cosmetic restoration, was last painted about 14 years ago. Paint job was done poorly but still looks good from a short distance. Rear quarters have bondo around fender lip and there is bubbling between doors and wheel wells repros are now available. Vinyl top is bad. Front inner fenders rusted around hinge mounts. Interior is showing it’s age and will need restored also. Dash pad has small crack starting, gauge cluster is uncut and nice with stock am radio. Door panels nice also, basically needs headliner, sail panels, package shelf . Has cloth buckets from an import in it right now but I have a set of correct stock buckets and an extra rear seat that go with the car that will need recovering.
The transmission is wounded , the 2-3 shift has gone soft. Car is driveable but care is needed when shifting into 3rd. I’m including a spare core trans and a slew of other spare parts with the car. Bring a truck to haul it all!
The 451 runs real hard, I had it to the ¼ mile once and it runs low 12 easily. With some rear suspension work and some more tuning 11’s should be easily attainable. The engine has good street manners and is a blast to run. Less than 1,500 miles on this engine since built.
I’ve had this car 16 years and have lost interest, so it just sits in the garage.
I’m sure I’ve forgotten some details, please E-mail with any questions.
$9,000 Cash talks, BS walks......
E-mail: beepbeep71us@yahoo.com
