44070Swinger
Brand New 452 6pac Stroker ported Edelbrock 84cc heads 2.14 Intake and 1.81 Exhaust valves. Stage I street/strip port flowed 285 cfm @550 lift. The 400 block has been square decked and line honed. Crank is a forged steel unit. Compression is 10.25:1, .060 KB pistons. Rods, factory LY rods w/ ARP rod bolts. Cam shaft is the a Mopar Performance 509 cam, Specs are 292/292 509/509 @114 and 1.6 ratio roller rockers. Mopar Performance Aluminum water pump housing and pump and Mopar Performance black wrinkle valve covers. The motor is fully balanced to within .2 tenths of a gram.
The engine comes with a lightened 11 Flywheel. The engine is Fully assembled and ready for delivery.
Dyno results, flow chart for heads, and balance report come with the engine. We ACCEPT VISA and MASTERCARD.
This motor Made w/ 1-3/4 headers 537 horse and 519 ft lbs torque w/ 2" headers It would have been 557 HP Only reason we didnt test the engine with the 2" TTi headers is they didn't fit on their Dyno
YOU WILL NOT BE DISAPOINTED W/ THIS COMBO
raysmopars@Gmail.com
9500.00 OBO
77 400 Bored 60 over square decked and line honed
69 440 forged Steel crank
Windage tray
HV oil pump
Kb 451 Stroker pistons lightened and balanced
MP 509 Cam 292/292 509/509 @114
New 6 pac intake new carbs ands air cleaner all inkages and fuel lines
New 1.6 roller rockers
Smith Brothers push rods
LY rods ARP rod bolts
Rotating assy ballenced to .2 tenths of a gram
Engine was built and dynoed at Flow Techincs In Poulsbo Washington
9500.00 OBO
Windage tray
HV oil pump
