Grant GT 14" steering wheel. Virtually new condition other than the tiny rust on the hex bolts. Fits anything with the right adapter package; current adapter is from a Conquest TSi. I have not tried it on a Mopar column. $25 + shipping.
_________________________________________
M-body 125MPH Certified police speedometer. Odometer shows 03539 miles. There is some dirt on the face but it can be removed with household cleaners or a fingernail (you won't hurt the markings, trust me). $30 + shipping.
Cop wheels, blasted, DP40 epoxy primed, and painted. Two wheels have runs/sags that need to be sanded out. Finish on these wheels is not correct, it's GM Pewter on the faces only (black elsewhere). No caps. $200 + shipping, offers considered.
Mopar P4529484 clutch kit for 8-3/4" Sure Grip, Dana/Spicer "Powr-Lok" (the clutch type). New in box, still wrapped in cosmoline paper, with instructions. These are the more-aggressive clutches. $40 + shipping ($66 from Summit).
Carter ThermoQuad 9182S. 1978 400HP, good rebuildable core with the all-important ported spark vacuum fitting. Everything moves freely, but definitely needs a kit (I'd do the floats too... it's how I roll). $40 + shipping.
Floor-shift shifter and linkage for '71-'79 B-body and '70-'74 E-body models. Complete with two shifters; one is the short '70/'74 style that used the walnut-grained shift knob (which I do not have) and is a true Slap Stik gate. The other is a taller shifter as used on '75-up B-bodies, but it is not a Slap gate. The shifters and bezels interchange and both shifters work fine. All linkage and bushings are included, right down to the tailshaft bracket for the transmission. Front floor-tunnel bracket is correct for all consoles, the rear one is the taller style that will require modifications to use the rattle-trap E-body console (it sits too high). I will include the floor tunnel section with the console brackets if desired but it will add to shipping due to length; otherwise I'll cut 'em off (they can be located by the shifter once everything's connected). $100 + shipping for everything.
Message me here or via PM if interested. Yes, I'm going to empty my PM boxes.
